RE: PLEASE HELP BURNING UP SERVOS
Hi,
If the servos are smoking there is a serious problem with something, most likely the servo reverser. Don't use it and reverse the servo through the radio or as jester described, or come off the opposite side of the second servo with the push rod. Don't rush take your time.
To assign the flaps to a master and slave:
Press down and select at the same time to enter function mode.
Press increase or decrease to select the master channel.
Press select to highlight the slave channel.
Press increase or decrease to select the slave channel.
Hope this helps,
Cheers,
Colin
