RE: Servo Reverser ?
Yep, the servo plug has 3-wires: battery positive, battery negative, and signal. If those get switched around it won't work at all.
I've never opened one up to switch it inside but I know it can be done. Better be confident in soldering though. A bad joint could end up causing a crash.
