RCU Forums - View Single Post - 9lbs thrust, is it enough?
Old 03-13-2010 | 03:58 PM
FliteMetal's Avatar
FliteMetal
Default RE: 9lbs thrust, is it enough?
Without the thrust tube you said your thrust was higher without a thrust tube and 2:1 inlet lip than with
a thrust tube with an outlet diameter equaling 85% of FSA. OK, what was the result at 100% and 110%
of FSA?
