RE: I need a set of plans for a Thermic 50 R/C
Is it the one with the built up fuselage or the pod and boom style? Also is the wing the one with spars or just the wider leading and trailing edges that act as the spars? If it's "yes" to both of these questions I've got a set you can have. But it's just for the glider. You'd need to fudge on the power pod using the pictures on the box or from the web as a guide.
