RCU Forums - View Single Post - Blade SR no lift power after crash. Need help!
Old 03-15-2010, 06:49 PM
Ddaddy
Default RE: Blade SR no lift power after crash. Need help!
ORIGINAL: badmechaaron
To check the feathering shaft just take one blade off and turn the screw inside the grip and you will see the two grips wobble if its bent.
Ditto above...and you should be seeing quite a bit of vibration when she spools up.
Disconnect2 plugs going to motor and power up. Do you see the swash move down when you move left stick up? Positive (lift) pitch on blades?
triple check swash
Ken
