RCU Forums - View Single Post - Mounting Engine to Falcon 120 (Bobcat Copy)
Old 03-15-2010 | 07:04 PM
joeflyer
My Feedback: (49)
Default RE: Mounting Engine to Falcon 120 (Bobcat Copy)
Do you think the weight is the issue or the thrust?
The weight of the engine is a problem. There is not enough structure at the rear fuse. You can beef it up as many have done for turbine applications, but with a gasoline engine it will be heavy and will be a dog due to insufficient rpm.
Joe
