ORIGINAL: MsgtRob
My engine number is 352. It would really be great if this could be fixed by the user.
Couldn't agree more. The last engine I had that was not really user repairable (with necessary tools and experience) was a 1969 K&B 40 where the whole crank and bearing assembly was pressed together then the drive hub was drilled and pinned to fit the crank. There was also an allen setscrew but if it came loose, the roll pin could shear. Not a real friendly setup. I understand the Syssa requires the drive hub be replaced after it is removed ... Hmmmmmm! Should we be stocking up on these hubs or will someone volunteer to produce an aftermarket one like the DLE 30 people did with their backplate?!
