RCU Forums - View Single Post - FX Needle valve
Old 03-19-2010 | 08:11 AM
GSJames's Avatar
GSJames
Default RE: FX Needle valve
This is what I do on both my Open B combat planes and my Q-25 pylon racers. I use this aftermarket OS needlevalve:
http://www3.towerhobbies.com/cgi-bin...&I=LXCR48&P=ML
And then I attach it to the airplane using a large landing gear strap. One end holds the assembly and the other hole is attached to an engine lug. If you need a 90 deg angle on the attachment, you can use a control horn.
http://www3.towerhobbies.com/cgi-bin...I=LXDMG5&P=ML#
So far I have had excellent success with this method.
ID:	1400995   Click image for larger version
