RCU Forums - View Single Post - Bluejay XLT question
Old 03-19-2010 | 07:53 PM
  #103
klhoard's Avatar
klhoard
My Feedback: (10)
Default RE: Bluejay XLT question
Chuck,
Yessir . . . I figured that out 1.5 seconds after the first time I ran it up to full power. The coupler slipped off the header (BWWWAAAAAAA!!! - you know the sound!!) and then I went into the garage and got the zip-ties. The pipe was still sliding around a bit so I added another zip tie to the pipe holder help hold that. All part of the learning curve and I'm glad I'm learning them on the test stand.
It's good to hear that the coupler will seat. I don't think I'll need to remove the pipe on this plane once I get it set the way I need. I ran two OS 1.40 RX's on Icepoints for a couple years. . . I have become a big fan of piped two-strokes. Once those OS's were set up, all I ever did was add fuel, light the plug and bump the prop. From what I've seen so far, this engine is going to be just as good.
I've already found a couple really great features of this engine. The needle valve is a separate assembly from the engine. I have the needle valve mounted right now to the "firewall" of the test stand, and I still have to find a place for it in the plane, but it is nice to have the needle mounted to a solid surface and let the engine shake away on the Hyde mount. I guess "shake away" was a bad term. . . this engine is actually very smooth at all RPM's. The only movement I could see was the cylinder tilting left as it ran up to full power due to the torque from turning the prop.
Another neat thing is the prop mounting bolt has a recess in the end for a hex wrench. You can hold the prop shaft in place so you can really get some torque on the prop nut. I can't really describe all of the other differences forward of the front bearings, but there are many as compared to an O.S. The spinner backplate is a replacement for the usual thrust washer, so you don't have the slipping when they are two separate pieces.
ORIGINAL: Atlanta 60
Awesome!!
I noticed in your test stand picture you don't have any zip-ties or clamps on the silicone coupler...You may wanna think about using them to keep stuff from sliding around...I've actually seen a pipe slide out of the coupler while using zip ties that weren't tight enough.... . .<snip>. .
</snip>
