ORIGINAL: microDan
Sounds like you need to set up your end points for less travel and use some expo as they are very sensitve on the steering.
Make sure your steering linkage springs are set according to specs. when you hold the bike and shake it the fork should be floppy but want to go back to center somewhat. These little bikes can be a handful to setup and learn to drive. Good luck.
Thanks for the reply Microdan. So with that being said, I notice when I go full left and full right, my forks hit the side of the front fairing each way. Should I trim off some of the fairing or do like you mention and check my end points? I'm pretty easy on the streering, I fly heli's as well and I'm all over the sensitive movements and all. The steering is floppy like you mentioned. When I adjusted the servo horn, I moved the metal sleeves so the spring was just touching the sleeve and the plastic middle piece....On both ends...
Thanks again for all your guys help. I really want to get this bike in control.
