RCU Forums - View Single Post - volcano s30
Thread: volcano s30
Old 03-21-2010 | 01:32 PM
RCToysNh
Default RE: volcano s30
ORIGINAL: deejstylz
just had my nitro s30 out the other day and up to this point everything has been great unti al of a sudden it only had front wheel drive.. new to this so not sure if it is in the central gear box or the rear end..someone please help.. thanx
larry
2 things to check.
1. Check that the main drive shaft to the rear and the axle shafts are still in place.
2. the drive cups have grub screws that may have come loose. The main drive cups on the rear drive shaft most likely is just spinning on the shaft. the grub screw should be tight against the flat spot. A little lock tite will take care of screws backing out.
