RE: super chipmunk 120
Hey all. I have the CMP chipmunk 120 with an ASP 120 four stroke in it . I have to say that it is the perfect match for weight and performance. Plenty of reserve power yet not over kill. With a 6 volt 1200ma battery mounted right aft of the servo tray, behind the wing mount, it balances perfect with neutral elevator trim. This is typically further forward on cg than CMP calls for as they usually post way aft cg's. Only advice would be to make very sure you install the gear tight and facing forward. This plane flys like a charm. Goes where ever you point it and lands so slow and soft. Flaps make it really sweet. Great plane for the price!!
