RCU Forums - View Single Post - RCD 3800 jumper wire?
Old 03-21-2010, 09:46 PM
snuts
Default RE: RCD 3800 jumper wire?
I could go out to the hobby room. But, plug it in one way, try it on the bench. If it works it is right, if it is backwards, it will not work at all and will not damage it.
So don't worry,
1 - you won't hurt it
2 - It won't give you any mixed feedback, it will only respond if it is positive shift.
Then make sure it is plugged in firmly, also tape the crystal down to prevent vibration from loosening it.
Hope this helps.
-Snuts-
