RCU Forums - View Single Post - Removing canopy from an Escapade ARF
Old 03-22-2010 | 01:07 AM
Mikecam
Default RE: Removing canopy from an Escapade ARF
You have to move it forward to release the hooks in the back. Look from the bottom toward the back of the canopy and at either side. You should see two small slots with white hooks coming thru, make sure these hooks are forward enough to pass thru the slots. If they are then glue is holding it somewhere. Good luck.
