Old 03-26-2010, 02:35 AM
fatboy audio
fatboy audio's Avatar
Default RE: FTX = Nutech?
Hello to everybody..I am from Greece.
I just purchased a FTX-PUNISHER with the 23cc CY motor and made some modifications to run better.
With the factory exhaust the car was very slow,so i installed a DOMINATOR aftermarket exhaust ,and changed the needles inside the standard carburator with new ones from zenoah 26 carb.
The result was fantastic...
High torque at all rpm very good speed and excelent track control...
Its far the best petrol 1/5 scale model i ever had...
Next step is changing all the plastc parts with metal,like upper arms,servo mounts,engine mounts and hub holders,front and rear..
Also i found at DDM a cylinder with piston 26cc to change the stock 23cc.
Maik
