ORIGINAL: cheap tank
Thanks YHR i think they are a little to big but ok for my first try. I started the weld lines and some details on the turret. The .50 cal is not to bad with a little work now i need to find a crew.
Cheap Tank,
Looks great. I also upgraded the 50 cal. I cut the barrel off at the Handle assembly. Then used some plastic rod the same diameter as the barrel to fill in the empty space under the cooling shroudand reassembled. I also liked the hatch periscopes. did you scratch those or did you buy them. Great tank and keep the pics comming.
Jim
