RE: Extreme Flight Extra 300, 78
Started to work on this thing. First is setting the horns per the instructions. The kit is fairly well pre-fabricated so there isn't a whole lot for the buyer to build really. Mostly assembly.
Stab is factory aligned and so are the wing panels. I will check these to see how close they got. Hopefully I won't have to adjust anything....There is always something off alignment in ARFies in general and if this one is precise from the factory it would be a first.
The wing pins are aluminum and the fit is good....a plastic bolt hold each panel in place. Stab fit is good also. Stab is secured using a set of tabs on each half, which are screwed through to the fuse
