Trouble with 2 Aileron servos
I have a question about the setup im running, hopefully someone knows
I have 2 servos in the wing for my ailerons. Im running them into a Y harness and plugged into 1 channel. However it seems impossible to get the servo arms to be perfectly opposite to each other. Its like they are 1 click off on the gear compared to the other.
So when 1 aileron tracks full throw the other has a pinch more throw in that opposite direction, and vice versa.
The PROBLEM is that it causes 1 aileron to overthrow to far in the down position (because its the rear tapered ailerons) while the other is ok because its going up. And i cannot just use the trim for that channel, because it effects both servos.
Ive thought about sanding abit more taper in the aileron but it would be way to much to take off the back.
The radio i am using is Futaba 6ex 72mhz.
Anyone have any idea how i can fix this, im completly stumped atm.
