Old 03-28-2010, 11:43 AM
SeamusG
SeamusG's Avatar
Default RE: Ultracote Trim Shrinking
Bubble are not an issue. I always use the lowest possible heat setting whenever overlapping two pieces of Ultracote. However, low heat does not bring out the that beautiful shine. There is a threshold heat that will change both the texture and shine of the film. Easy to do on the base covering. My problem is that I haven't found the key to bringing out that shine from the film that is used to cover the base.
