RE: New to the forum with question
You might try heating the engine with a heat gun or putting in an oven for 10 minutes at 230 or so. Then see if it frees up or soak in some fuel for a day or two. On the corrosion, was there pool chemicals in the storage shed - I saw some badly corroded engines due to the chemical interaction.
