RE: Dumas 1/8 Miss Circus Circus build help
wow! that looks great. And again thanks for the kit. what is that in your boat? foam. Also how are you doing your front canard wings, the aluminum rod seams real heavy, are you using a carbon arrow shaft? Are the canard wings going to be operational? The cowl looks great, I can't wait to get one. Also do I need to window out the sponson inside frame or the cockpit framing towards the back of the boat? Heard some people on here say you don't want too leave any area closed up, so water can drain out if it gets in there. Thanks for the info. This helps a lot!
