RCU Forums - View Single Post - CG position question.
Old 03-30-2010 | 12:28 PM
gboulton's Avatar
gboulton
My Feedback: (15)
Default RE: CG position question.
Find the spar.<div>
</div><div>Balance it at the leading edge of said spar.</div><div>
</div><div>Go fly.</div><div>
</div><div>What you'll get, for any traditionally configured monoplane ever made, is an airplane that will fly safely, and land safely.  You may, of course, prefer a different CG (probably more aft) location as you move forward, but a "LE of the main spar' will get the airplane airborne without any scary stuff, and let you work from there.  </div><div>
</div><div>FWIW, Bipes also have a "safe starting point".</div><div>
</div><div>Find where the cabane struts attach to the top wing. </div><div>
</div><div>Select the point in the middle, between the leading and trailign attach points.  </div><div>
</div><div>Balance the plane there, go fly.</div><div>
</div>
