Well tank tray cut, sealed, and glassed in, tank lines set-up, not a great ton of room to get the hands in there to strap the tank down side to side like I like so zip-tie front to back fit the need.If your wondering what the black zip tie looped on the engine rail is for its to hold the fuel filter and line away from the engine-I should have flipped the carb over and ran the inlet to the other side BUT radio box is already set to run like it is..Also notice the paint fix, WOOPS had to fix a chip before i even hit the water with it lol
