ORIGINAL: D.DJ
Ahh, I see. Then like I said, any 1/8 size mounts should fit into it. Just make sure that there are holes in the right spot for the mounts to fit, otherwise you will have to drill your own holes for the mounts. Shouldn't be too hard, it's only a minor mod so it shouldn't damage the chassis strength. Just don't mess it up
I have drilled hole for motor mounts before but there are already holes in the chassis that look like they are ment for motor mounts so I was hoping that Kyosho made mount designed for the Inferno gt. I could just get mount for any 1/8 buggy/truggy and make them work but I would prffer to use the right mounts instead of having to drill the chassis.
