RE: eclipse dual elevator function
1) Make sure you dont have another mix enabled that would link the one elevator to the aileron channel.
2) Does your radio have the AILV mix in it? If so then you can use this mix to have dual elevators and not use a P-mix.
3) Can you test this same mix on a new model memory and see if it also links the one elevator to the aileron trim?
