ORIGINAL: logon69
Try using that in a 15:1 compression engine. You cant! If you are running a low compression (Stock) engine it will work but you do sacrifice power.
8oz of oil? Can you see with all that smoke?
ORIGINAL: badd_maxx.25
i run camp fuel with 8oz of oil to the gallon
Very true indeed about using low octane fuel in high compression engines, it just won't work at.
