RE: Conrol throws for Bipe
Never saw the post?? I would like a bit more power on that Bipe but that just a choice. Throws are pretty basic for planes until you get into 3-D. I use a degree meter on all my controls except rudder. I get all the rudder I can, the others I set up at 12 degrees up and down for high rates and 8 degrees for low then as I fly the plane I decide if I want more or lass. On bipes I often add Diff to the ailerons so I may set up my ailerons to 2 degrees more up then down to help the roll rate. Yes, Bipes do slow down a lot faster so you can shorten your approach.
