RE: Epoxy Mixing Ratios.....
Thanx for your responses so far, fellas....
The result of my "experiment" so far is that while the "mix" is not a "gooey mess", the small amount I mixed has not fully cured. You can press your finger into the epoxy and leave a fingerprint and you can stick a tookpick into the epoxy to see it has not fully cured. That small batch was mixed about 16 hours ago. We'll see what happens with a little more time....
Thanx for the link, Charlie. Looks like a good read !
Any more comments would be welcomed.......
