RCU Forums - View Single Post - Smoke system on Magnum 91 4 stroke
Old 04-11-2010, 04:25 PM
The Ghost
The Ghost's Avatar
Default RE: Smoke system on Magnum 91 4 stroke
It can be done, just mount your smoke system and tank to keep the CG right, If you rap the smoke pipe around the exhaust header to pre heat the oil it will work better. You will have to spend a bit of time adjusting every thing so as not to flood the exhaust with too much oil.
Cheers
