RE: Stuck Prop nut
I don't like the idea of the end of a bolt coming in contact with the piston while trying to remove the prop nut. You are obviously going to scratch and dent the piston. I would remove the engine head and/or the back plate and work from there. The crank is a solid piece of steel and can handle a bit more abuse.
