RCU Forums - View Single Post - Stuck Prop nut
Old 04-13-2010, 03:33 PM
Crash Campbell
Default RE: Stuck Prop nut
Hi,
There are many ways "to skin a cat" and all the methods mentioned here will work. When I'm faced with this situation I remove the plug, dribble some fuel into the chamber to ensure hydraulic lock, replace the plug and remove the nut. Check the nut and shaft for any thread damage and use a tap or die if either thread is damaged to repair it.
Cheers,
Colin
