RCU Forums - View Single Post - Stuck Prop nut
Old 04-13-2010, 06:02 PM
DGrant
DGrant's Avatar
Default RE: Stuck Prop nut
If the cowling won't come off because of the prop... cut the prop. If you do end up using something for a "jam".. first thing I like is the piston-stop device.. but if you can get to the back of the engine.. take the back cover off and use a wooden dowel for a jam... I wouldn't use anything metal for any jam, anywhere.
