RE: Need help wiring a motor control relay
Tony: You solved my problem! brilliant. Using a contact on outside of torpedo to activate motor is a great idea, especially since I'm running in salt water. I'll try and build this as you suggest. Any ideas on how to get a brushless outrunner to run in this application? I'm looking in to a servo adjuster/tester to send a dummy ON signal to the ESCs.
