Use one receiver for multiple airplanes with this gadget. I probably have $500.00 worth of Futaba R617FS receivers alone and I am sure some of you have much more. If you could easily move you receiver from plane to plane to save $80 per plane would you?
There is a company I have used to make something similar to this if I have a bunch made at once its much cheaper. I am thinking about having a lot of them made, even for different radio systems. I am looking for replies on weather people think they would purchase and or use something like this before I go out and make a whole bunch of them. I think they will cost 9-15 dollars not sure yet.
As shown in illustration, the circuit board shock mounts to the plane with all the servo leads hooked to it. Just plug the receiver in face down on the connector and slip the antennas it to the tubes. Don’t forget to change models on your transmitter.
If I make one for the Spectrum I will have to figure out a way around the model match feature.
