RE: Now what - part 2
Mike,
Looking at what is happening to mine should support be extended to the little wire.? As you say the environment where it is located is pretty harsh. I don't see any really better locations as where it is now is about as far from the Motor and ESC as it can be. If I extended the plastic antenna support tube a little and slid a 1/4" long piece of fuel tubing over the little wire and the tubein the center of it that should absorb a lot of the vibration. What do you think?
Jim
