Servo has no strength in ONE direction?!
Hey guys - I have an old servo I was thinking of using, until I realized that if you pull on it one way you can easily pull it back to neutral. the other direction seems to be holding just fine. Obviously I'm not going to use it as is, but is this a gear issue that could be fixed by replacing the gear set?
