RCU Forums - View Single Post - motor stopped working....
Old 04-18-2010, 03:54 PM
John_jrp3
Default motor stopped working....
Ok, i have a century swift. i decided to upgrade the 4s1p to a 6s1p as the manual says i can.
i went out hovered around dialing in the pitch and throttle some landing a few times to do so due to higher headspeeds now as the tail would not hold with my current setup. after the 3rd time i go to take off and the motor twitched like i lost a leg on the esc.
I bring it inside to check it out closer. the motor is very hot, keep in mind i never went over 75% throttle speed on this.
I ohm out the motor leads and they are getting continuity between legs, not sure how to test the 3 phase dc motors. and im gettin 12k ohm between 2 on the esc
i just got this not to long ago and have hovered it around the yard almost every night for a few weeks at around 80-90% throttle. on the 4s1p battery.
I was doin some research and ppl say dont run ur throttle at under 100% for over 30 seconds or it may burn up ur esc and motor? this true?
so maybe when i jumped to the 6s1p battery i flew for a minute or so and it fried it? before i always checked after a goot 5-7 minute flight and neither the motor or esc was hot till now.
any body know how to test the motor and esc on these?
and also why i may have burnt them up
