ORIGINAL: -barcelona-
It looks like you got the plugs on the recharger the wrong way around which in turn shorted your batteries when you started charging..
I reckon the fault is yours are not the chargers.......
How the heck did you reckon that?
You are sooo wrong! The cheap charger was the culprit and for your info, the plug is hard-wired into the charger. In fact, I am sure now that it was the cause of another set of batteries for another car to fail (it exhibited the same burnt battery look but I thought it was a defective battery)
