RCU Forums - View Single Post - Wheel Adapters
Old 04-21-2010 | 05:08 PM
TCA999
My Feedback: (32)
Default RE: Wheel Adapters
I believe that as long as you go from 17mm to 17mm you should be fine depending on the tire/rim. Certain tires are wider and taller than others which can cause the tire to rub on the inside of the front A-Arm when turning.
