crash nothing wrong
I have over 40 flights on my revolver. 9303 , ar 6200, all digital servos, 2700 5cell battery. under 300mah load battery was 6.68 volts. flew for 8 mins or so. came in to land and on the base leg lost it for split second then under control. did this three times in two seconds. the last time lost every thing. plane rolled twice then hit the ground. when got to the sceen battery switch was in off position.
once back in pitts. battery volt was 6.39 under load. every thing worked back in the pitts. range check out to 130 feet was good.
Anyone have a clue what might have happened? could i have got shot down with 2.4???????
