RCU Forums - View Single Post - Which Starter
Old 04-28-2010 | 04:15 PM
Tauri Flyer
Default RE: Which Starter
I have the same engine. They are high compression and your going to need better then your average 12 volts to crank it. Even the Dynotron has trouble at 12v. I use a 2200mah 4 cell lipo,,works perfect! Also you'll need to get that motor wet to start it and fuel draw with hand cranking just doesn't get it on that motor. Shoot it a prime and bingo!
