RE: FLYZONE Playmate
I too, agree with the above reviews. I have had a ball with the Playmate, only problem that I have had id the prop came of and I had to glue it back on. That was a minor detail, although I had to slice the fuse open to gain access to the shaft so I could push the prop back on with som ca glue. I didn't glue the fuse back, only used scotch tape to put it back so I can get back inside easily. I have flown the Playmate indoors in a small gym with ease, it also flies very well in a bit of breeze, moreso than the Vapor. I also have a Vapor and Ember, the Ember is almost as good in the wind as the Playmate but not quite. The transmitter is small but is easy to get used to.
