RE: Nitro Hawk build
well i got bored while cleaning my rs4mt so i decided to tackle the engine on this bugger and it seems that all is not lost, the bearings, depite the surface rust, seem to roll good enough but i will replace them regardless. the crank shaft is also rusty but not beyond serviceable. the piston and sleeve are also in pretty good shape, maybe if i could find a chemical that breaks up rust that isnt wd40 i might be able to get everything running.
ill update after i do some homework on which parts are compatible with the trx .15
