RE: Skidoo Rev XP snowmobile hop-up
Hi Joe, just purchased one of these "slowmobile" it was used for 10min. for 30$ not bad i think? She's all stripped but having hard time taking the motor pinion off. I noticed your stock motor still has the pinion on, how did you get it off the transmission? Also how much run time do you have on this thing and is the stock transmission still holding up? I Might have more ?'s later hopefully you don't mind helping out.
thanks
Harry
Edit again, guess no ones home? anyway i ended up cutting the motor shaft to get it off the trans.
Still need to find out if the trans. has held up to the punishment.
Also is that a micro servo?
