RE: Need more top end
more teeth on the clutch bell, i think it comes with a 13 tooth clutch bell so you can get a 15 tooth clutch bell but it will take away from the bottom. also you can get an top end pipe for example the Dynamite 086 pipe will work great. very durable and gives it a good bit more top end.
hope this helps a little.
