RE: RCM CESSNA 0-1E/L-19 BIRD DOG Build
Second wing starting to look like the first.
I finally got around to making the landing gear block and installing it. It was way too much work without a hobby table saw. I recommend just buying a pre-cut hardwood landing block. Otherwise, it requires freehand routing with a Dremel tool.
I probably should've done this far earlier. Having the gear on will mean being able to set the thing on the table upright without it rolling over!
