RCU Forums - View Single Post - Large eletric setups
Old 05-16-2010 | 08:01 AM
MaxAdventure's Avatar
MaxAdventure
My Feedback: (7)
Default RE: Large eletric setups
ORIGINAL: vik
The point was to use smaller motor and smaller battery and get same result as with direct drive.
I know the direct drive is possible.
Well, you will have a friction loss on the drive train, you have additional rotating mass as well as additional dead weight - this all will absorb your watts into the system with a lower watt percent available for spinning the prop so you will end up with bigger batteries. The suggestions are provide the most efficient and simple way to power a large electric. The one place I still see smaller higher KV motors useful is using geared in-runners when you have a very tight mounting area like some smaller turbo prop scale applications or a performance sailplane.
it's really quite surprising how small (weight and volume) a good out-runner is compared to the equivalent petrol IC engine.
as for not addressing your power source for battery charging:
ORIGINAL: vik
For field equipment: do you use car battery or have some external power source?
I mostly keep enough sets of packs that I don't need to charge on a day I fly. I charge at home starting a few days before a planned flying day using a very large power supply on my CellPro10 supplemented by a few other chargers for smaller and Nickle based packs. My primary club field has installed a solar collector and Pb/Acid storage and we often charge packs at the field from that. I do know some fields have A/C power available and I've often seen personal petrol generators in use at events. I personally used to charge smaller packs (3S 2000mAh) off my car battery however between fear of running the car battery low and damaging it (not a deep cycle) and fear of LiPo thermal-runaway fires (most of my packs have experienced some bumps and bruises - never had a charging fire yet) I have stopped that practice.
