RCU Forums - View Single Post - Prop Size
Thread: Prop Size
Old 05-19-2010 | 11:21 AM
opjose's Avatar
opjose
Default RE: Prop Size
You can also switch to a three blade prop to help with clearance problems.
When stepping up to a three blade prop, reduce the diameter by 1" to compensate.
e.g. if the manual calls for a 14x6, you could substitute a 13x6 three blade prop and achieve almost the same performance.
