RE: need suggestion for best method to paint a pattern on a wing
But as far as what parts to paint first would you start (with a white wing) and put the N5K positive area stencil on the wing first, tape off the sunburst pattern and paint the red sunbursts (then remove all the tape). Then I am thinking I should take the negative outline of the N5K stencil and put it in place where it will be painted and tape off the white sunburst pattern only where the leters are. Then of course the rest of the wing will just be masked off so nothing else gets painted. I am thinking If I mask all that off it should just reveal the "to be painted red portions" of the letters in the white sunburst area. So then I would paint those areas red and peel off all the tape again and it should be done.
If you can understand what Im trying to say above, is that what you would do?
