ORIGINAL: Budman68
Turn it up to 11 [img][/img] Not sure what my issue was or is, but the first couple of stock plates kept stripping out the cover screws. Ordered the STRC plate and I kept losing the mount screws. Finally just added bolts and nylon nut.
Note to Thread starter. If you want out of control and the ability to jump a house, install the Havoc Ballastic 8.5. This is one fast set up.
ORIGINAL: redfisher1974
ORIGINAL: Budman68
I would suggest bolting through the engine mount with counter sunk screws and nylon nuts. My Novak 8.5 vibrates the mounts right off, regardless of the amount of loctite you use. Other than that, it's bulletproof.
Funny my havoc 8.5 has never came loose on my storm.
Thinking about it doesnt the blitz have a different motor plate with a heat sink? And my havoc is turned up to the max on 2s with a 21 pinion.
